Brakes
hi i am going to change the rear axle on my mk1. it as got drum brakes on. can i put one on with disc brakes. with same handbrake cable or do i have to change it. forgot to mention its got ABS and traction control.
no need to change the rear 'axle' or subframe.
just change over the stub axles and hubs. you will need handbrake cables and brake hoses to suit though
i am going to change the axle. the one that's on is very rusty. so i fort wail i was changing it i would put one on with disc brakes .
fair enough. its pretty straight forward to change, just heavy
Just make sure that you find out about whether the brake master/slave cylinders need changing to allow for the increased fluid transfer.
No changes required on the mk1
Pshaw, the job's a doddle then ;)
Basically lol
Hi thanks for the advice all i will go for disc then
