"transmission Tunnel"
I'd like to fix something to the top of what I can only describe as the "transmission tunnel" behind the handbrake.
Does anyone know whether or not there is anything vital on the underside?
I'm using the shortest screws that I can, and they only protrude 8mm from the bottom of the item.
Can you show us the exact location?
Possibilities are brake lines, exhaust, fuel line.
TBH most likely thing you'd find first is a heat shield.
Best to get the car on a ramp or lift and have a peek.
Don't do it purely on a jack though - very dangerous unless axle props are used and even then risky.
