¿odbii Mk3 Location?
Hi everyone,
¿I like to know if anyone can tellme where is the ODBII location on a Focus MK3? I Can't find it on the owner manual (even my old fiesta owner manual has it). I saw pics on google but is for the MK1 and MK2.
If you guys can put a pic or tellme the location, I really appreciate it! ;).
Thanks.
Solved by Stoney871
Hi Edu,
Sit in the driver seat, it should be knee height on the dashboard (normally in line with the light switch). If its not on the dash behind a panel, then look in the armrest area in the centre of the car and then look behind the ashtray.
I dont know exactly where it is as I have never had the pleasure of sitting in a MK3, but these are the common places. It may also be behind a small panel, so look out for a door in the dash area.
  • Solution
By European legislation the port has to be accessible from the drivers seat so it will be within arms reach.
Hi
In mine it is behind the coin holder drawer just below the headlight switches. If you open the drawer and squeeze the sides it will drop down (make sure you empty the drawer first, as everything will fall out!).
Max.
Thanks for all the reply's ;)
Did you find it in the end?
