Should I Change Timing Belt Tensioner
Hi all
My Focus is a 2001 Black 1.6 and i am going to change the cambelt soon. The service history says that a timing belt kit was fitted in Oct 2009 at 85,000 miles. The car is now on 104,000 m. Should i replace the tensioner too as it has only covered 19k miles?(as has the belt).
I have read that the belt should be changed after 5 years, does that go for the tensioner too?
All replies appreciated in advance.
Cheers
Simon
Belt change 10 years or 100k or on mark 1.5 it's 8 years or 100k if u replacing belt again have to replace tensioner just for piece mind u be sick if use old one an something happen
should be a timing belt kit so belt tensioner and new bolts is a must
You will be wasting your money changing the belt at that age/mileage. As a confidence check, try to contact the garage that stamped the first belt change to confirm that it was done. If its true then don't worry for another 50k miles
