Ford Foucs Loss Of Power And Shuddering
hi all
new to the foucs stuff, i have a 2002 focus and all of a sudden there loss of power and abit of shuddering, my wife was driving it lol. i thought it could be the ht leads so ive replaced all them but still doing the same, could it be the coil then, if i take plug number 1 out, the car will start but it will not start if plug 2 out or plug 3 out but it will start if plug 4 is in, am i correct in saying its the coil
thanks all
Certainly sounds like the coil, you will need to replace the HT leads as well.
i thought it was ht leads so ive replaced them first lol so ill be buying a coil tomorrow
just be careful, if you only installed the leads yesterday you should be ok, but disconnecting them and moving them can easily break them again, so be prepared that you may need to buy more in worst case scenario.
grrrr fook sake, xmas comes and everything fooks up, can only afford to buy coil, the car just sitting then till i get the coil, so hopfully there ok, lol rant over, just having a bad day
lol Look at the day and the date, its all understandable.
As I say, to be honest your leads probably will be fine, as long as your not vicious with them!
yes, ill blame that date lol, always before xmas
hi all
ive replaced the coils and the car seens to be running fine but the fault light is still on, is this cause the fault is recorded in the ECU and i need to get it plugged in to turn it off
cheers
Just check the wiring make sure everything is all secure. You can disconnect the battery for up to an hour, that should reset the light. Then if it comes back on again, you need to look at other issues.
the engine light is now off
Hoping that it stays that way for you matey :)
cheers mate
