Gs8000L Dashcam Review
Ah ok, nvm, it's working.. It didn't seem to do that push and click thing the first time, but now it does...
..odd but now working :)
  • Replies 91
  • Views 35.8k
  • Pictures are back now :)
  • mixmasterlooney
    mixmasterlooney
    I like this james any pic of it? Sent from my GT-I9300 using Ford OC mobile app
  • I will take a snap tomorrow of the setup and get it uploaded tomorrow. Big D, Yeah a lot of it is the compression ratio. I have the video's on my computer (original clips) and it has a very good pict
I take it it's a micro SD card.
word of warning, it you need to take it out while the camera is in situ, be very very careful.
I have mine just below the rear view mirror
One day I thought I'd remove the card in situ. Well it flew out like a rocket, hit me in the shoulder area, and disappeared. What a job I had finding that.
You know from experience, you drop something in the house and it ends up under the fridge or the settee or the sideboard a foot or two away, requiring the use of a 12 inch ruler to retrieve it
Well first job I looked down over the top of the drivers seat in that area between the seat and the cockpit centre consul, zilch.
I had the drivers floor mat out, I checked every inch of the drivers floor carpeting, under the front of the drivers seat. I checked the rails the drivers seat traverses back and forward on. I checked every bit of the centre consul, the gear stick gaiter. I went in the back and checked behind and under the drivers seat, not a sight of it.
I slide the seat right back and viewing from the front and twisting my neck [in the process nearly pulllng a muscle] I finally saw it. There it was snaged on to the verical side of the floor carpet as it heads towards the centre consul, like it was a mountaineer clinging on to the North Face of the Eiger. Did it want to let go, did it b@ggery, and me fearful of dislodging it without holding onto it, and it falling down behind the seat rail. Seat out and all that, or attempted retrieval by vacuum cleaner suction.
But I hung on to it thankgoodness.
YOU HAVE BEEN WARNED ONE AND ALL :rolleyes:
Hahaha, yes it is a !Removed! micro sd card... A right pain in the wotsit..
I'm having all sorts of troubles with the !Removed! thing at the moment - I'm assuming this is more the damn card than the camera!
Yup had my mobius sd card shoot out like a rocket before
James, in order to get files off the camera can you just plug the camera in to the computer? Or do you have to take the memory card out?
Either or, I find its just as easy to tug the camera out plug in download and reconnect. Easier overall imo.
Hmm mine doesn't work, they've told me their supplier said it's 'impossible' to do so... Those rats!
Sent via carrier pigeon using Ford OC
You plug it into the taptop and turn the camera on then it should ask you if you want the camera mode or mass storage mode.
I believe when I plug it in WITH the memory card in, it doesn't register on the computer that it's been plugged into the laptop...
Have young tried different USB ports and also checked device manager, it could be it hadn't installed a driver yet?
Ian not being silly here, but are you sure your putting the card in the right way round.
problem could be that you think it is in, but it is not hence the PC ain't seeing it.
What you have right now is a situation in that you don't know if its a USB slot issue, a camera issue or a micro card issue.
if it were me I'd take the card out pop it in a SD card adaptor, pop it in an SD card slot on your PC, or in my case I pop it in a SD card adaptor , which I then slot into a SD card to USB adaopto. Then see if your PC recognises it. If it does that will illiminate the card and the PC being at fault.
  • 1 month later...
Digging up this post I have just bought the very same camera James has for £19.89 (link).
Anyway my question is what have done to hard wire into a 12Volt supply?, I bought a USB charger last year and hard wired using this to switched 12Volt supply in the passenger cabin fuse board/GEM module, and I have one of the add-a-circuit link spare to I will disassemble the cig power adaptor and wire it via a switched 12Volt supply in the fuse board/GEM module again.
Hope that info is of any use?
For my mondeo I just bough a motorbike 12v supply. Cut the rings off, stripped the ends, poked in to the connector block for the rear 12v positive and negative, then secured the wires in place with amalgamating tape. Works an absolute treat. Alternatively you can use a fuse tap (piggy back fuse) and add an extra a circuit direct). Good luck with the cam Kevin
  • 2 months later...
Hi Jeebowhite and everyone else, I'm new to the forum.
I have just bought one of these cameras (GS800L) and believe it or not the instructions I received are in Chinese (I presume as it looks like Chinese to me) I have worked out a lot of what to do but still not fully working. I have tried it with a 32Gb card in and it says "Mass Data" so I have put in an 8Gb card and this seems to be accepted.
I would settle for a camera that turns on when I start the car and re-records over itself all the time every minute. If I could then stop the camera when needed ie. after an accident, that is all I require. I only need the last minute before a prang not the whole journey I have made.
I do not know which settings to achieve this with, if anyone here can help I will be very grateful. My other idea was to take it to my local Chinese take-away but they may not be of much help.
Thanks,
Glynn
Hi mate,
Mass storage appears when your plugged into the computer, my cam has a 32gb in with no issues.
The camera turns on automatically with power there is an auto record function on the menu. Mine automatically records and switches on with the car because the 12v is ignition live and not permanent. It does also have the loop record. When you power it on it starts in video mode so press menu once to configure the settings, use up and down buttons to navigate the menus and click record as the OK button. You can set the game sensor sensitivity, and in the event of any hit at that he force will automatically save the last video and the next 60 seconds.
Hi again, I still am having problems, basically because I don't speak or read Chinese. I have made a list of what I can and would appreciate help on the settings I should put in to the various menus.
As far as I can make out
there are 4 pages of menus
I have copied them and to the right hand side is the setting I haqve entered. Which needs adjusting, please?
When then camera is turned on
there is a video camera in the top left hand corner, when the menu button is
pressed once the first menu appears as follows. This I have called MENU 1
SIZE 1080FHD
EXPOSURE 0
WHITE BALANCE AUTO
ANTI SHAKE ON
LOOP RECORDING 10 MINUTES
MOTION DETECTOR ON
RECORD AUDIO ON
DATE STAMP ON
When the menu button is
pressed for the second time the spanner symbol is lit and a second menu appears
as follows. This I have called MENU 2
DATE
ON
AUTO POWER OFF 5 MINUTES
G SENSOR LEVEL 2
BEEP SOUND
ON
BACK LIGHT 3
MINUTES
LANGUAGE
ENGLISH
FREQUENCY 50HZ
TV MODE
PAL
IMAGE ROTATION ON
FORMAT
CANCEL
DEFAULT SETTING CANCEL
When the video camera is in
the top left corner and the MODE button is pressed video camera is replaced
with a still camera. If the MENU button is pressed once the following menu
appears, I have called this MENU 3
CAPTURE MODE SINGLE
RESOLUTION 7M
QUALITY SUPER
FINE
SHARPNESS SHARP
EXPOSURE 0
WHITE BALANCE AUTO
COLOR
STANDARD
ISO
AUTO
SCENE MODE AUTO
FACE DETECT FACE DETECT
ANTI SHAKE ON
CONTINUE SHOT OFF
the top left corner and the MODE button is pressed the video camera is replaced
with a still camera image. If the menu button is pressed twice the spanner
lights and the following menu appears which I have called MENU 4
DATE
ON
G SENSOR
LEVEL 2
BEEP SOUND ON
BACK LIGHT 3
MINUTES
LANGUAGE
ENGLISH
FREQUENCY 50HZ
TV MODE
PAL
IMAGE ROTATION ON
FORMAT all data will be deleted CANCEL
DEFAULT SETTING return menu setting to defaults CANCEL
Thanks,
Glynn Fletcher
I would advise loop recording as 3 minutes, motion detection off, it should them auto record for as long as it's plugged in and it should automatically overwrite the disk when it's our of space.
Thanks Jeebowhite, I'll try that fix and report back.
Glynn
Thanks Jeebowhite.
It works brilliantly. Quality is pretty good considering.
By the way I only paid £9.00 for the camera, brand new on ebay from China including post and packaging.
Not bad eh?
Not bad at all! I was happy to pay 20 for it, heck it's recently caught another idiot on camera for the police to investigate on top of two crashes and the theft of my car... It really is worth it!
Glad you have it set up and ready to go! Are you hardwiring it in!
Hard wired it in and it's brilliant. The rubber sucker sits on the black part of the windscreen and the actual camera hangs down slightly below and is very difficult to see from outside. I live in the backwoods where nothing happens really but when I venture into civilisation I am now prepared. Thanks for everything.
Glynn
(PS. I Googled the make of the camera originally for help as my instructions were in Chinese and the only place I could find any help was off Jeebowhite on the Ford Forum. I used to have a Ford Popular 50 years ago so I joined the forum to converse. Sorry if this upsets anyone. If I get a brick through the windscreen of my Saab 9-3 I know where to start looking for suspects)
Glynn Fletcher.
Happy New Year everyone.
Haha, no worries matey, I'm glad to be of service. Car regardless, it's good to welcome people to the forums and offer help. :-)
  • 4 weeks later...
Hi all
jeebowhite - been following this post for a little while and your posts have been most helpful!
I'm about to buy one of these dash cams myself, but just want to clarify how you hardwire them in please?
Many thanks,
Sewy
I did it differently as I hardwired a spare 12v socket under the dash, then used the lead provided to plug it into the 12v
It's easy and cheap and offers better fuse ratings so won't blow up lol.
Glad this has been of use to you :-)
Jeebowhite, well have had issues and it turned out to be a dodgy tf card, anyway got a SanDisk tf card and now records all video without switching off after 10 minutes, so all good now.
