2010 1.4Tdci Fiesta Engine ??
Does anyone know if you can get to the crank easily after removing sump on the above engine??
What u mean why u want to get to the crankshaft
I need to get the crank because it needs new conrods so I wondered if you take the sump of do you get straight to the crank or is there like something in-between??
Think there still something in ur way u will have take head off to get it back in where u gettin a piston I thought u have replace short block if any issue down there
What would be in the way?? and the heads already off and it's bent 3 of the 4 conrods so needs new ones
Can see the nuts on big end
Forgot that I'm just gonna put a new engine in it it's an easier option
Wel ford won't give u spec they say any problems replace short block second hand or recon be so much easier for u to do an save so much time
No getting a second hand engine and replacing the job lot cba with the time ripping apart the crank and stuff so full engine is coming out and new one going in!!
Ford was gonna charge £4500 to replace it we've got an engine for £600 and we'll fit it ourselves
Update on this, new engine is coming this week and me and my dad will be putting it in this weekend i will post some pics and stuff of the engine change so if any of you guys need to do it know whats going on :)
Yeah keep us update any problems give us a shout
New engine arrived today so should be starting it tonight
Old engine out new one ready to go in today here's some pics post-44432-13895284122_thumb.jpgpost-44432-138952842233_thumb.jpgpost-44432-138952843349_thumb.jpgpost-44432-138952844368_thumb.jpgpost-44432-13895284556_thumb.jpgpost-44432-13895284667_thumb.jpgpost-44432-138952847755_thumb.jpgpost-44432-138952848925_thumb.jpg
Is it just stood on very big axle stands? U drop gbox out with it?
Sent from my Hudl HT7S3 using Ford OC mobile app
Yeah it's stood on axel stands sat on wooden blocks and yeah dropped them both out together then changed the box over onto the new engine
Engine is in and ran but only used fuel in the filter and won't pull anymore from the tank anybody got any ideas??post-44432-138955255463_thumb.jpgpost-44432-138955260521_thumb.jpgpost-44432-138955262392_thumb.jpg
Did u prime it
Doesn't have a prime pump any ideas how to prime it??
U need buy primer ford cheap don't have electric pump in tank u need prime system before u start it
How much is it??
U can buy them cheap in a motor factors
Awesome cheers
As I've put a new engine in and it's no longer in warranty I'm thinking about modifying it slightly 1st job replacement stock air filter with k&n panel air filter has anyone done this and does anyone know the performance advantage and mpg gain thanks is advance
Engine running well and no leaks of any kind next job get a new k and n airfilter :)
