Timing Belt
Hi guys I've just been quoted £223.08 for a timing belt change including tensioner. But the chap said the belt doesn't run the water pump. Im sure I've read on here somewhere that its recommended that the pump gets changed the same time as the belt, save taking it all apart twice.
focus 54 reg
1.8 lx tddi
It doesn't run the water pump, but you cannot normally access the water pump without taking the timing/cam belt off, so they often recommend changing the water pump while you have everything off.
Ah ha I was misinformed then tyvm
