Filling Up Tank Minor Problem?
Hi
When I fill up my tank with diesel it keeps shutting off and I have to hold the handle only a little down so hardly any goes in the tank , even then it shuts off.
If I squeeze the handle all the way it just shuts off.
I'm not sure if it was the pump or my car but its happened a few times now and is a bit annoying.
Any ideas?
thanks
Certainly try another pump as the cut off could be playing up (I think it works using a vacuum)
If it's the same at another pump then it could be a blocked breather on the diesel tank.
I always hold the nozzle a bit out from being fully inserted or, as you've found the back surge triggers the cut off.
what Clive ^^^ says
thanks . just have to wait till next fill up and see if it does it again.
