My New Mobius Dashcam
That's true but you can clearly see his hand go back onto the handle bar and after the engine reving you can see him pass. I will try my luck with it because it really got me all upset
Sent from my GT-N7105 using Ford OC mobile app
  • Replies 675
  • Views 85.9k
  • mixmasterlooney
    mixmasterlooney
    As promised boys and girls i have made a guide on how to hard wiring your mobius with step by step instructions on exactly how to hide away all cables. Special credits to James (Higgsy) for his idea,
  • Quite happy with my Mobius set-up's now! Front Rear:
  • Haha blatant running of a red light by that accord on the night vid!
I've been looking at one of these cameras for a while, and it might have come in very handy today,
I narrowly missed knocking down a teenage girl on a bike,
Slowing down and about to turn left on a terraced street, this girl comes flying out on wrong side of road
straight across the front of my car, if I had been going straight on I have no doubt I would have hit her,
I gave her a few words out the window as she went past.
Definatey worth raising the point Kurt, they might be able to follow through on it, but I would say the evidence is more circumstantial and not definite, so they may be able to do very little, even if they have a word, its good to know that he has hit their radar at some point!
As for you Ian, that is bad! if you had hit her, then you would have had one heck of a fight proving that it was not your fault! at least with a cam you would have had the extra supporting evidence
I bet you got a few :censored: words back too :lol:
I just tell these people there on borrowed time! :p
I generally include a few choice words to go with that sentiment
Sent from my SM-P600 using Ford OC mobile app
Forum friendly translation, of what I said,
"You flipping silly-person!"
Sent from my HTC Sensation Z710e using Ford OC mobile app
haha, somehow I think the only word that was actually used out of that statement was the word "You" I suspect that the other words began with three letters such as F S and B!
I'm going to order one with a ribbon cable extension, going to mount the camera lens to the top/bottom of the rear view, and then the unit to the sensor area of the rear view mirror with velcro tape, that was it's completely invisible at more than 6 inches :P
Fellas how is things with the moboius still going?
As I said in my mother post I got mine the other day.
Just want to know is the PDF guide still up to date?
I want to hardwire mine into the car as a fit and forget.
Has anybody any hints or tips on doing this and can I be linked to the cable form the instalation?
Sonic the guide is done by me and James. Yes it is upto date it's done with my mobius in my Mk2.5 ZS so you aren't gonna get any more accurate of a guide than that I will try and post up the cables and bits needed later. I will also sort you out a link for a reliable 32gb sd card used by Ben in his mobius
Kurt
Excellent. I wanna get all cables ordered so I can get on with installation.
Great wee cam , upon testing it does get hot but then again it cools down fast as well. But like you guys said nothing to worry about.
I will be keeping the battery in it and maybe change to a capacitor way down the line unless you guys recommend differently?
Quality is first class for all the size of it. It goes to show that dash cams actually don't need a screen lol!
Are people getting the normal lens or the wide angled lenses for these? Managed to pick up a Mobius minus a lens for £14 :P
I got the normal lens (lens A).
Its more than enough for the job in my opinion. If position in centre of window it got a great viewing angle.
I think Kurt had the standard lens as well but not 100% sure.
I do indeed have the standard lens (lens A) it's more than enough I won't be getting the other one.
I'm about to order my second mobius for the rear, searching up on accessories to see if i can find anything cool
Well Kurt having read your hard wire guide, I've just ordered the Mobius and the bits and bobs needed including a Kingston 32GB micro SD card, came to just short of £59.
I had a mini fuse bridge and 3 amp fuse in stock from when I converted my foglamps to DRL's. And I may install a rear facing one at a later date.
I've been meaning to do a guide in regard to converting the Fogs to DRL's, cost litle money less than £25 if I remembere rightly.
Also a guide to installing an additional 12 volt socket, just to the right of the "coin cubby hole" for the use of my Satnav
Going to get me one of these shortly, especially after an incident on Friday. Approaching a slight right hand bend and could see a cyclist coming the other way with a car behind him. The car driver only started to overtake him didn't he? I saw that it was going to be a close thing so foot off throttle and covered brake, applied brake when I figured out he wasn't going to get in front of cyclist safely. He 'just' managed to get in without causing a collision!
How he didn't see me coming I don't know. I was driving a 2.5 metre tall BRIGHT ORANGE Renault truck at the time!!! A quick blast on the airhorns made sure he knew I was there :)
So a quick question about the Mobius, I have read all/most of the 18 pages so might have missed it, but is there a button to press to save a segment of recording?
Yep
Do you leave your dash cams on permenantly? My folks bought me a Next Base Halfords Dash cam which is really good i'm just not sure if it would drain too much power if left on when not using the car?
At the moment i have it on motion sensor so when ever i pull away it starts recording.
Mine is setup with an ignition-live in the fuse box.
Motion detection through the windscreen is crap lol
I have noticed that the way i have it set up it will stop recording if stationary for a few minitues but starts as soo as you set off again.
I wouldnt know how to wire an ignition live lol
Don't have a mobius, but I recommend you have it running when the car is running really... If you're stopped in traffic or something and you get rear ended or someone rolls back onto you...
With the ignition live guide I made you can always keep the camera running with engine on by leaving the ignition on. There is an option for a 10 seconds delay before shut down after power loss, this will allow you to switch off your engine and switch ignition back on without disturbing your camera power flow.
I know, the only way that i have read to ensure its on always is to press the record button at the start and end of my journeys, but knowing my luck i will forget to turn it off one night and the battery will die :P
Sent from my GT-N7105 using Ford OC mobile apI
I shall have a look at this guide
