Spark Plug Recomedations
Brill thanks. What is the recommended gap for the plugs or just put them straight in when Come. Cheers
Sent from my GT-I9505 using Ford OC mobile app
Those NGK iridium ltr5ix-11 are gapped at 1.1mm. Some will tell you 1.0mm, however if you check the NGK catalogue it will tell you 1.0 for mk2 and 1.3 for mk 2.5. Then again it also shows the ltr5ix-11 as a straight upgrade.
My mk 2.5 1.6 (albeit the ti-vct) has tr5b-13s in it. They were there from the factory and I replaced with the same too.
Sent from my Nexus 5 using Ford OC mobile app
The plugs should be gapped at 1mm but is think the plugs I got wee already pre gapped to that so I put them straight in. No issues with idling or anything
Sent from my HTC One using Ford OC mobile app
If this problem I get is the plugs how come it mainly only happen when the car seems to have warmed up? It has fsh and was serviced last October but was wondering if it include a new fuel filter??
I know on my focus the fuel filter is built into the fuel tank, so is not changed on a service
a lot of it will be trial and error until you find the right solution I have changed alsorts on my car, nothing made a big difference and luckily new upgraded plugs solved it. It might not for you, just depends on how much you want to go with finding the issue.
Well my car been coughing as I call it from when I left the house alway to wrk. Really p ing me off now because it's not right. Feel like a nodding dog after I get out of the car lol. Ford reakon nothing wrong but it def is and only one month warranty left so want it sorted. The car should be smooth even cruising in fourth gear, but it can slightly cough. Help on this please guys because I not been happy since I got it and it's a lovely car :(
When you say Coughing, does it feel like a misfire, mine was all jumpy and kangarooy around roundabouts in 2nd gear with high revs. Is there a particular issue at a certain amount of revs is it low down up higher up the range
It feels like a hesitation when trying to accelerate off in these gears but it's intermittent??
What u mean was?? U got yours sorted then??
Think I will get new ht leads and a coil pack in my local motor factor over the weekend and give this a try. Is is easy to fit the new coil pack in??
Stupid question now. How many coil packs will my 2008 1.6 petrol have because I have heard you can have more then one??
My mechanic is gonna test drive my car next week to see what he thinks the hesitation could be. He said possible ht leads or coil pack on way out. Gonna put new ht leads on it anyway I think.
I replaced my coil pack and ht leads with proper ford ones and it didn't really make a difference
Well I don't know what to do now then?? If it's not them then I got one messed up car unless all focus 's are the same??
Well I replaced my coil pack and new ht leads so see how it goes. Got my mechanic looking at my breaks Saturday to see if need pads and he said he will have a run in my car to see what he thinks.
