Bluetooth Retrofit Mic Problem
I am looking at putting bluetooth in my 08 facelift I have the right headunit with the right firmware, I also have the bt module connector behind the glovebox. The problem is the mic leads only go as far as a connector halfway up the a pillar then stops. What's the best way to get it to the courtesy light, run some wire down and into the plug from the courtesy light or is there a lead I can get from ford?
post-50942-0-59767700-1392015819_thumb.j
post-50942-0-74735800-1392015866_thumb.j
post-50942-0-92626000-1392015908_thumb.j
