Lamda Sensor
Just wanted to ask .Went to change a Lamda sensor on my Mondeo 2005 2.5 with a Bosch replacement.
Unfortunatly the two connecting lugs are in a different position.Can I cut them off so I can fit the sensor.
The pins and main connector are correct just the lugs in the wrong place.
would make certain you have been supplied with the correct sensor, they all look very similar but many are actually different..
if it is correct, then yes you can, but good connection is vital, so make sure its stable and water tight...
if it was me, id get that sensor changed for exact copy
