Mechanical Help Needed
Hi all,
My focus has been playing up with an intermittent fault, i have tried many things to cure it but its still there. Basically what happens is the rev counter drops to zero and the car bounces down the road, if i ride the clutch for a bit the bouncing stops but the rev counter stays at zero but after a few seconds it clears itself and may not happen again for quite a while. i have fitted a new coil pack and had all the breather pipes changed but its still doing it. does anyone have any idea what it could be?
Sounds like it could well be a faulty instrument cluster, have you had any other symptoms?
Could be the VSS (Vehicle Speed Sensor) in the gearbox. Changed a few of them for the same symptoms, but beware the pin you need to remove in the gearbox to get the sensor out is a right pain in the butt.
Does it stall if you dip the clutch or stop at junctions etc?
