Fuel
How easy would it be to take the fuel out of my mondeo tddi I'm scraping the car and I'm getting another diesel
And have half a tank of fuel
shouldnt be too much of an issue, you just need a pump and a reel of hose or pipe, put it into the tank and set the pump off.
Can I syphon the old fashioned way? Without a pump because I'm guessing by the time I've brought a pump is it really worth the hassle and moneu
yeah standard syphon should be fine, just bear in mind how your going to start the fuel flow - by mouth is il advised!
I've seen on YouTube put a pipe in to the tank and into a can then put anouther pipe in a use a towel to cover the hole then blow into the second tube?
I think you need to blow direct into the tube that is carrying the fuel, if you use a fuel primer bulb, you could use this as the trigger to start the syphon process!
