Central Locking Issues From Key Button
Hi there,
Not able to lock the car from the button on the key? I've changed the battery although the original one still had life in it.
I can lock the car via the door lock, but when i lock it the indicators flash and all the doors lock, however i notice that the red "i" is flashing on the dashboard? When i unlock the door and get in there a a contant chime and unless i put the key in the ignition and turn it the alarm will go off.
I've tried resetting the key (truning the key to position 1 five times etc), but that won't work, i.e. i don't get the chime when i turn it 5 times?
look forward to hearing from someomne with a bit of knowledge.
Many thanks
WD
I had a similar problem, fixed it yesterday.
Try fuse F21 in the central fuse box (under glovebox), it's a 5A and is located halfway up on the left (nearside)
