Mis-Diagnosed Problem
Good evening all,
Just after a little advice,
I took my 58 plate Ford Smax into main dealership today. I told them I had a problem with my brakes, I told them at 60mph when I applied brakes I had severe steering wobble and that I may have a warped disk or brake binding. I had new discs and pads on the front last year, (genuine ford ones) they told me they would check them and get back to me. Went to pick car up and they have replaced back brake discs and pads. Receptionist went and asked the technician to confirm that everything was checked and the problem had been rectified. £240 lighter I took the car and drove home, took it upto 60mph and hey ho, steering wobble still there when I applied brake and now back brakes getting seriously hot and burning smell from pads.
Rung dealership and they have told me to bring it back tomorrow.
Where do I stand as they haven't fixed the problem?
with you saying burning smell i would tend took look at the caliper for fault.....
Ahh ok, but both near side and off side rear brakes had burning smell. Didn't have burning smell before I took it in, would a caliper cause steering to wobble when brakes applied,
Sorry not mechanically minded,
Just a bit p***ed that they said they have checked everything and sorted the problem out and the problem persists and may have caused more problems
any kind of steering wobble is unlikely to be caused by rear brakes
but what kind of 'wobble' are you getting
vibration through steering column or
steering wheel shaking, ie.. moving left to right
If you had 2 hands on the wheel when you touched the brakes, you can see you hands judder left and right, sorry for the rubbish description. I would say it was similar to an unbalanced alloy wheel when driving at speed
It's normal having a burning smell after brake disc and pads changed, its the oils being burnt off but that does not explain the wobbling
Sent from my automated robot M1X-M4573R-700N3Y
silly,but have you checked your wheel bolts are tight?
I haven't checked the wheel bolts, was assuming the highly trained Ford mechanic might have done this. But saying that, who knows, I will check now just in case
Bolts are tight
You get this sometimes when the front pads have been overheated at some stage. Often if they haven't been bedded in properly before heavy braking. I have had three cars do this in the past. I changed the front pads, took it easy for a couple of hundred miles to allow these to bed in properly before any heavy braking. Things were fine after that.
what you describe will be front brake/steering/suspension related..nothing to do with rears
tyre out of shape
caliper problem
play in suspension ball joint/bushes
tracking
tyre inflation
distorted disc
play in wheel bearing
just a few examples
btw, would complain with regards to rear brake work in order to cure a steering wobble????
though doesnt mean to say rear brakes didnt need doing
I'd say by the symptoms that the brakes are out of balance.
One brake biting before the other would definitely cause a wobble.
Thanks everyone for the responses,
Been to Ford this morning, technician took car and myself out on test drive. After 5 mins, steering started to wobble when brakes were getting hot. Technician said he was 99% sure it was front brakes and couldn't understand why the rears was replaced, told him that I had front discs and pads changed early last year, and he says that's probably why they thought it was the rears! but they should have checked all the discs. He says it could be one of a number of things. A warped disc due to over heating, or when I had the front discs changed if they didn't clean the hub properly the discs wouldn't sit correctly and cause misalignment. Or it could be the spindle and wheel bearing?
Have to take it back next week so they can check which one is causing the problem.
Why didn't they check in the first place? My rear brakes may have been ok and not the cause of the problem.
When the discs are changed, the "run out" is supposed to be checked (that the discs are sitting square/ right on the hubs) and as the disc turns, the disc does not "wobble", it even has a tolerance, where a small amount is acceptable, and too much is not
An S-Max does not have wheel bolts, it has wheel nuts, that go onto studs that are fixed to the hubs, it may be a small point but it may be important
oils meant to be cleaned off for breaking... ive never had a experience with a burning smell after changing disks n pads.... if there was oil residue left on them then you would have no braking at all
It is meant to using brake cleaner but ford will never go through that much effort doing a good job the minimal is done... even then when done right it can still smell
glad you feel better for that, :P :lol:
