A Lot Of Grey/white Smoke When Cold And No Pull
An 04 tdci..
Engine's also very rattlely and smokey and was idling on 3 then after a few minutes went on 4 (I think), it's been sitting for 4ish months maybe longer, it's revs not to bad (still a lot of this smoke though) when I started to drive, when in first it hardly moved and my foot was dm near to the floor. I tried going into second, it pulled slightly better but not much
It's got a (seemingly) genuine 90000 from a mot history check, the car is general's in very good shape, just this engine problem. I though either injectors/s, turbo or seals, egr....all 3
Seller wants 600
Not hellish much happens here
Blown turbo seals? Have you checked turbo for bearing play?
If you havent bought it, walk away! Your going to spend a lot more time and money and stress diagnosing the issue I can guarantee you that much!
My money is on the injectors. The turbo won't cause it to run on 3 and if the smoke was because of the turbo it would more than likely be blue.
As above, I would walk away.
If the oil is being vapourised and not burned the smoke will be white. The fact that it's running on three could easily be a piece of turbo has been ingested and ruined the engine.
If it's oil that's being burned or fuel?
