My Clutch Rod
Yesterday my clutch failed, I had to call out Greenflag and the guy said the bolt on the clutch rod had fallen off, he fixed it,
My question is how much would a new bolt cost, seems a silly question, but i know nothing about cars
The usual fault with these is that the rod from the master cylinder slips off the rod on the pedal. This happens once it's worn a little as there is nothing holding it on.
You can buy a washer from the likes of ebay which will solve your problem.
As far as I know there are no bolts.
Something like this
http://m.ebay.co.uk/itm/181370976345?nav=SEARCH
I have successfully used a good cable tie and also a small jubilee clip on another car without any issues.
Well the man from greenflag said it was fixed, i will have a look on amazon and see if i can get one, thanks
happened to me in my fusion and i fitted one of the ebay washers and its been fine since
