Low Rpm
Hi I have a mondeo 2.0 lx tdci (130) and when I turn the car on it sits at around 500rpm for between 10-30 seconds with the battery and engine management light on, yet after 10-30 seconds both lights go off as the revs pick up to normal tick over? Any advice...thanks
Could be as simple as the Mass Air Flow sensor needs a clean, have you got any error codes on it?
Hi mate, no it's been on 3 different diagnostic machines and only re first one brought up a fault of the EGR valve so changed that and it's no different, since then re other two machines havnt brought up any fault codes it had a few people scratching there head!
Did you clean the MAF?
No still at work mate, another lad said to clean the EGR valve, another said to get the injectors recoded?
you could do all of those to be honest, cleaning the MAF is easy with electrical contact cleaner, the injectors can be recoded with ELM Config, and the EGR could be removed and cleaned thoroughly
Ok cheers all that went straight over my head mate I know nothing about cars! But I will suggest it to my mate, thanks a lot!
Its really an easy process, it involves a starhead screwdriver (torx) and some electrical contact cleaner, and then drown it in the stuff :)
It will 100% need injectors
It will need injectors
