Duraetec He - Tappets Clerance Adjustment - Help
Hello
I've bought a 2001 Mondeo 1.8 Duratec HE.It has a diesel sound, presumably the tappets need adjustment.
Its not flaps - those were disconected by me. I need a good mechanic around the Manchester area who will be able to help me. And btw how much does it cost roughly?
Thank you for any advice
They use buckets for tappets think u need put some sort shims in wat mileage it could be very expensive job camshafts could be worn are u sayin u broke flaps out inlet manifold
I did disconnect pipe that goes into mainfold . That disable flaps? Milage is 130k. As far as I know buckets need to be changed. No shims in durated. Those ones are in zetecs. That's why I need good mechanic around Manchester to sort it out.
Your talkin major money chain an camshafts would have be removed then price new buckets how much would u value ur car at
Its not worth much ;0 I know that. It look like all day job - plus time to order correct size buckets. I do have timeing chain set - get it with car. Just wondering how much it can cost. And im sure it need to be done because car do have lpg instalation - and that requires tappets clearance to be checked more frequently. I even consider drive to let say poland - holidays kind of ;0 and have it done there ;0
I be lookin at 5 to 8 hours labour depends on where u bring it who did LPG conversion I would do dry and wet compression test aswell before u do it see wat condition ur engine is
