2001 Focus
Hi all
I have just got myself a 1.8 2001 Focus Tddi, I have come across a couple of problems that I would like to sort!
First one is my rear wiper, when I move the stalk to turn it on it cleans a quarter of the window then stops. I have to keep turning on and off to get it back to base. Any ideas?
Also I have issue with central locking, my rear drivers side door doesn't lock from fob and when in car if I try to lock all doors from my door, none lock except mine. Suggestions?
Any help would be great cheers peeps
Ryan
The wiper problem could be the switches in the motor itself, the motor is easy to replace and cheap fpr spares on ebay.
I would recommend that you get the wiring in the rubber tube between the roof and hatch checked for breaks first as it can be a common problem.
As to the locks, iy could well be water getting in to the lock mechanisms, taking off the door cards, visually inspecting the mechanisms for corrosion and liberally spraying with WD40 may help.
Sent from my SM-G900F
