Location Of Glowplug Relay On Mondeo Mk3 Tdci
Hi I have just drilled out, removed and retapped 4 sheared off glowplugs ,on fitted new ones,there seems to be no power supply feeding the newly fitted plugs despite the glowplug light still flashing I suspect the glowplug relay but having viewed some 2nd hand ones advertised on ebay I am unable to locate similar on the car.Can anyone shed any light on where it is found ,thanks
K70 is relay.
I think F3 is the fuse going by the wiki
Hi Many thanks for diagram found a blown 60 amp fuse as the culprit not the relay as suspected
result! quick fix then!
