Mk2 Focus 1.8 Duratec He - Coolant Temp Problem
having similar symptoms so no need to start new thread.  car recently started pinking constantly when feathering throttle.  if I blip throttle at tickover, you can now hear the air filter drawing air, with a slight delay in revs picking up.  mpg dropped around 9 mpg.  temp on test menu is 87c when driving and been sat ticking over for 20 min, test reading of engine temp not went above 99c.
Anyone think it's worth trying a thermostat.
  • Replies 52
  • Views 35.9k
  • The temperature gauge shows a value which is completely calculated by the PCM. this is not a realtime value measured by the temperature sensor. The needle going to the middle within 30 seconds has not
  • If its a petrol then yes it should get up to 90 its therefore overcooling so the thermostat is likely stuck open
  • TomsFocus
    TomsFocus
    I haven't read the rest of the thread, but the thermostat on this engine doesn't open until 90c.  It sounds like yours is working fine.
  • 10 months later...
I was entering test mode today for the first time and saw Engine Temp avg around 118 with a spike at 127 and i was scared but after reading this thread i'm sooooo happy.Thank you.2009 Focus 1.6 Ti Duratec Ghia Titanium.
