Mondeo Mk3 Tdci 2.0L Glow Plugs Limp Mode
Hi I am new to this I have a tdci 04 plate 2.0l ford mondeo the car was running all Ok the glow plug started to flash car goes in to limp mode and then cuts out car can be turned off and back on and back to normal
I have plugged car in to code reader and P0251 comes up
I have changed fuel filter
Bought new imv
Done injector leak off test and 10ml in all 4 after 4mins
Cleaned egr valve
Changed pressure sensor on fuel rail
Changed all fuel pipes
Put new turbo and actuator on
Checked all boost pipes for leaks and all Ok
Bought new boost valve
Changed maf sensor
Checked all turbo pipes all Ok
Also made my own fuel tank and made no difference
Also checked fuel pump pressure all Ok
This codes has come up and when plugged in to code reader I clear code and run car and it comes on when I am in 3rd about 3000 revs
Has anyone's else had this problem and fixed it as I am lost at what it could be
