Ford Mondeo St Tdci Wobble Whilst Accelarating
I have a mondeo st tdci 2007 model, it wobbles whilst accelarating and does this in any gear.
I have changed the crank shaft pulley, the alternator belt and pulley to. This has not resolved the issue, any ideas please help...
A little more detail required. Where is the wobble coming from? If it's from the belt area as you indicate it might be, can you see the belt going side to side as it runs?
It's not coming from the belt area, I did get all the pulleys changed from there initially as I assumed that is what was causing it. It is a side to side woblle which only happens whilst accelarating.
I'm thinking it could be something to do with the transmission, like the drive shaft for example.
