Help To Understand Focus Modifications...
I have just purchased a focus zetec 2.0 with quite a lot of mods, just as a track day car, just one thing i'm yet to pick it up and don't quite get what exactly is done to it...
Was wondering if anyone can help?
This is the description...
uprated adj suspention on rear uprated front handles like go kart 4 branch 4.2.1.manifold big bore exhaust with scorpion back box /upgraded coil pack and leads forced induction kit /fuel boost gauge /front strut brace /quick shift /push button start /sparco sports recliners seats cost new £550 new discs and pads hid xenon lite kit
Whats a fuel boost gauge?
Exactly and what does it mean forced induction ? Haha
Sent from my Nexus 4 using Ford OC mobile app
Isn't forced induction code for super/turbocharged? Or is it the case that this person has fallen foul to the electric supercharger con I wonder?
Thats what I initially thought it was a turbo or supercharger, whats this electric supercharger then I've never heard of it?
forced induction
This is a mushroom style filter or cone induction filter which is open to atmosphere,
In some cases it may hace hoses feeding to it, dubbed forced induction.
Boost gauges are for turbos
Ive never heard of a fuel boost gauge lol
The car has a 4-2-1 exhaust manifold which is 4 pipes narrowing to 2 pipes then to one pipe which feeds to the rear of the car,
This results in smoother flow of exhaust gasses giving better throttle responce.
The car is lowerd on adjustable suspension, possibly coilovers,
It may require laser tracking alignment to prevent excessive tyre wear.
As saw in image this is result of negative camber, this is prevented by laser alignment which corrects camber after lowering
Overall mate the cars had roughly 1,500 spent on it,
Judging by the spec too, its been driven hard quote "like a go kart"
Bare in mind you can build the same and possibly had less hardship if you bought a standard spec 2.0 and put these parts on yourself,
Its not really that much modified,
Forced inductions do more harm than good, and 4-2-1 exhaust gives maximum 15bhp increase,
Has it been remapped or a fuel rail box fitted.
if it was turbo it couldnt have a 4-2-1 manifold
Okay that's cleared up a lot then thanks aha
fuel boost gauge
once it reads empty, tap it and it auto re-fils
fuel boost gauge
must be based on WW2 aircraft gauges then :lol:
lol, big bore = turbo whistle fitment lol
What they said lol
What they said lol
:) if i was to type it all out, the autor of this thread would think "that guys a negative A-hole and doesnt know what he's talking about"
But when you link videos that have over 20,000 Likes, they must be speaking some truth.
And i know we spoke a bit about turbo there, and the car in question not having one.
Well in my opinion the car is a good base, and having a 4-2-1 manifold i wouldnt sacrafise that and go fitting a turbo,
If it was mine and i had a spare 1500-2000 to put in to it,
The car would greatly benefit from an Induction Throttle body upgrade,
Or ITB's as there called,
This modification would be around 700 cheaper than turbo, and would provide up to 40bhp increase
With greater torque and throttle response through out the rev range
Unlike turbo which has lag, additional nose weight, and only kicks in between 2,000rpm and 3,500rpm
Throttle body's would give you the better edge on exiting corners,
Just my opinion,
There are off the shelve kits available on eBay for most naturally aspirated and unnaturally aspirated engines.
Thanks for the advice Lenny I'll look into it :) as I said anyway this is just a car to take round the track not to race.
