Fiesta Brake Light Not Working
Hi guys,
I have a 58 plate Fiesta (not the new model) and my drivers side brake light is not working. Passenger side and centre brake light are fine. Side lights are working ok on drivers side but nothing lighting up when I brake. Had a look and there are 3 bulbs in there but if it were a bulb problem would the side lights also not work?
Not sure whether it's just a new bulb/s from the local motor store that's needed or do I need to pop it along to a garage?
Any help much appreciated
Is it a 2 filament bulb? If so check that one isn't broken
Sent from my MY SAGA C2 using Ford OC mobile app
Thanks for the advice. Just checked and yes they do. Didn't realise the bulbs had 2 filaments in. Looks like a bulb change is needed. Will pop along now and get it sorted.
Thanks again
No worries, if you want an upgrade go led have a look at my bus build thread there are led bulbs and links there you may find useful
