Mondeo Estate Zetec 2.0 Air In Fuel Pipes
Mondeo runs ok .with out caravan on soon as I put caravan on. and tow then switch engine of it gets air bubbles in fuel pipes will.not start up . Had new fuel filter on and checked .can any body help ? ?
sounds like there is too much air in the system for sure, have you checked the fuel lines to ensure non are marginally split? when the engine load increases the vacuum increases, so what is a tiny pinprick hole might as well be the grand canyon under pressure.
Thanks will have a good look
