Car Spec
I guys im trying to my chaiss plate work I want to restore it to original spec what do Al0 and PA1 mean tried to enclose a pic
post-58595-0-58011300-1411662560_thumb.j
Or if anybody co6ld decode thr full plate it would be a great help thanks
Not sure just how right I am on this, but the nearest thing I could find is this:
This is how I think it translates!
1) Type Approval Number: 0020202V
2) VIN Number: WF0 - Ford Werke A.G., Germany (European vehicles) - Cabriolet - XX - Ford Of Germany - Rheine assembly plant - Escort model (apparently :P) - manufactured 1990 (apparently) - Manufactured month July - Sequence number - 11337 -
3) Gross vehicle Mass - 1400
4) Gross Train Mass - 2300
5) Permitted front axle loading - 725 kg
6) Permitted rear axle loading - 725 kg
7) Steering - LR (Left Rack?)
8) Engine - Illegible
9) Transmission - Manual 5 speed?
This is about all I can decode so far,
This is what I have figured out,
Wf0 Germany Ford werke
L 2 door cabriolet
Xx. not used
G. model line, Ford Germany
K. factory id, karmann
A. Model escort
L. Body type, cabriolet
E year 1984
0. Month?
Sequential no 11337
Drive B rhd
Engine lr cvh
Trans W 5speed manual
Axle N...... No idea help
Trim KV no idea help
Colour PA1 not sure sunburst red......???? Help
If you are having trouble using the online decoders, maybe a call to your local ford dealer may help you get the information you need? :) They will most likely have a more comprehensive database.
I used the online sites and reference ones to get this far just thought some one on here would of known what KV trim is? Thanks for help I shall pop into days and see what they say
No worries, hope you manage to figure it out. For the record i think paint code PA1 is Radiant Red from what i could find out, but again Ford would probably be your best chance of finding out. Good luck :)
When I did a hpi check it said the car was black/red, 14 owners between 84 and 98 bonkers!
