Transit Connect T230Lx
I have a 2008 transit connect t230 (110) the turbo is whistling when I change gear any body know what this is ?
  • 2 months later...
Hi check that there are no loose pipes ore loose clips from the turbo
remove the turbo pipe and check for a lot of play in the turbo shaft, a small amount is ok.
is there a lot of oil arund the pipes , are you using oil
change the oil and filter, it could be that the oil is the wrong grade
look at the air filter it could be that the engine is not breathing
have you got a inter cooler it could be blocked
I have fitted a new turbo cartridge to a cleo and that whistles at high reves
If you are not losing power
good luck john
