ring gears
hi can anyone help me with my 1-3 2000 fiesta makes a horrid squalk sometimes when i try to start it ive been told its the ringgear can anyone give me some hints on how to remove the gearbox is it easy? does the subframe come out? can i do it up my drive? thanks for any suggestions
id try another starter first mr
I'd take the starter out first and have a look, you should be able to see the ring gear to check for damage, turn the engine all the way round and look for worn teeth, also check drive on the starter.
You will usually find wear in 2 places on the gear (3 on a 6 cyl) as an engine will stop on compression.
Also check thast the ring gear is square on the flywheel, I've not seen it for years but the ring can slip.
