Fiesta 2001 Rear Washer Relay
Hi First post
I have a Feista 2001 1.6
I am trying to find the location of the rear washer relay
when i use the rear wiper it works fine but when i switch it off it does not go back to it's park postion just stops where it is would this be the relay
thanks for any help
If the wiper doesn't park its either a broken wire, usually between the body and the tailgate or a bad switch in the wiper motor.
With the ignition on check for 12v on the Violet/Blue wire to the motor, if voltage is good its going to be the motor.
post-4806-0-08341900-1412757220_thumb.jp
Hi Dan
Thank you for the reply will have a look the weekend
