Starting
Hi all I have another galaxy now it's a 2003 1.9TDI
When I start her she runs for a sec or 2 then cuts out again have replaced 1 of the relays so far and have the others ordered but if this doesn't work does anyone have any ideas what the prob could be as need it back on the road it's like losing a leg Just miss the comfort lol. Thanks
could this be an immobilizer problem?
whats the red light doing on the drivers door when you try and start the car?
do you have another key,just to rule out a problem with the key you using,
oh and have you dropped the original key by chance?
The light is off then flashes like mad when it cuts out again
Only have 1 key for her
so have you dropped the key,sounds like an imobilizer problem.
you have a pm.
No haven't dropped the key. So might have to get her plugged in and see if they can reset it
the reason i ask,if you had the pats chip has a tendency to drop out and peeps dont realize it has then have problems starting.
so weve ruled that out then.
So looks like it's the Immobiliser so have to get it plugged in and see what the computer says I need
That's the problem with all this stuff in cars now
you can buy a lead for around a tenner from ebay then done load vag-com.but as its the free version will only do the basics.
not a green gal ghia is it? LF03 ---
No it's just a TDI none of the nice toys in it is green
Has N.Ireland plates and first reg here
Thanks for all your help in the end it was the chip in the key so got it reprogrammed and all good now
