Mystery Squak
Hello,I have recently had a squeak from my front off side wheel. It has got progressively worse over time. It squeaks and whines heavily when you turn right and clunks when you turn left. There seems to be a bit of vibration in the track rod arm but the noise is a strange one. Any suggestions please?
Hi
It sounds like it might be a worn driveshaft joint or maybe a worn top suspension mount.
John
Thanks John,
It really is a strange one. My mechanic friend (20 years) has had a good look at it. He says the noise is unusual and doesn't want to recommend me replacing a part which is incorrect. When I reverse of the drive slowly it squeaks (this is the only time it squeaks when going straight). It turns peoples head in the streets when going round round abouts etc...and you can feel it in the steering wheel when turning left but it is less high pitched when going left?
