Sail Speakers
Hello people, just a quick question.
How do I remove the sails which hold the tweeters? Is it a case of putting the window down and them pulling off? I dont want to go ripping them off and breaking them. Its a MK2 5 door focus.
Thanks guys!
They just pull off.
Open the door and just pull directly towards you.
Stoney871 thankyou ever so much for the reply.
I was going to attempt fitting new components in this weekend.
The front grill of the tweeter seems to move but I stopped as I didnt want that breaking aswell.
Iv seen the 'how to' on removing door cards and stereo upgrades but fails to mention the tweeters just rip off.
Kind regards. Joe
They're usually just held on with small metal clips with teeth on them.
They should look something like this-
post-28494-0-00850100-1417536604_thumb.j
Absolutely spot on mate. Would you say I need a small flat head screwdriver? Should I start at the top of the tweeter or lowrr down on the inside door part?
Nothing much I can break then?
When removing the door card, should the tweeters be the first thing moved/remove out of the way?
Thankyou again
Best regards. Joe
The worst you may do is scrape a plastic tab or two unless you yank on it like a church bell ;)
I would say remove the tweeter before the door card as the casing curves over the sill and may hinder removal.
Thankyou again stoney.
Iv only had this car for 2 weeks and wanting to put my previous install in the motor. Well after all, i do 64 miles a day and need my tunes.
Kind regards. Joe
