No Brake Lights And Coil Warnig Light
Evening All,
Need help please?
Galaxy Mk2 1.9TDI 53 Plate
Firstly had a problem with the lights which when pedal pressed ( Lights On ) released ( Lights On ) slight pull up of pedal and Lights out.
Now have no lights when pedal pressed and coil warning light Flashes !!!!!!!!!!
To Ford got a replacement Brake Switch £20 and Green. Fitted and still no Lights and Warning light flashes
So With that checked all fuses, Looped pin 1 and 4 on connector and Lights on. Ok fitted new switch connected and nothing again.
Tested Pins 1 and 4 on meter no circuit...Tested 2 and 3 Open Circuit.. Tested old switch and 1 and 4 open circuit. 2 and 3 no circuit
Both tested off and on the bracket
Pin 1 - Red / Yellow Stripe - 12v
Pin 2 - Black / Yellow Stripe - No Idea
Pin 3 - Yellow / White Stripe - No Idea
Pin 4 - Black / Red Stripe - No Idea
Haynes and Tis does not show what Pins 2,3 and 4 actually do or go to
Anyone got any idea what is going on please?
Regards
B
