Drivers Side Window Switch
I have a 2006 fusion and my drivers side window switch was sticking so ive bought a new one and i am unsure on how to change it and advice will be very much apreciated thankyou
Do you mean the electric window switch?
I think you have to lift and prise off the door handle panel trim and then disconnect the switch wiring plug?
Yes its the window switch and do you know where i would start to pry the trim off
Thankyou
Haynes manual appears to suggest lifting it from the back (nearest the rear of the car first) then shows a tool being inserted at the front (on the side) to prise it off.
Would this be removing the entire door panel or just a section
Thankyou for the advice
Just that section. Bit of a pain to do the whole door card!
Thanks ill give it a try tomorrow was gunna take all the door card out so that'll save me some time
  • 1 month later...
Did you solve the problem?
