Come Home Lights
Anyone got this function on thier car?
Can it added in to the current wiring. ?
I've read that if you pull on the light stalk before switching car off then lock up the lights will stay on until you lock up and then come on when you unlock.
Now do I pull up the stalk before leaving when car is running so that high beam comes on of do I switch off then pull on the stalk then leave the car??
Thanks.
Turn ignition off, pull stalk and exit car. Headlights stay on for approx 30 secs but you need to do it every time you want it.
At least that's how it worked on my 2.5 Focus. Haven't tried on my mk 3
Cheers for that I'll give it a go.
That didn't work lol
I had it on my 55 plate CMAX so I am surprised you dont.
Did you remove the keys from the ignition before pulling back?
Yeah, I even did it with key in so the lights flashed.
must try this next time out in car just to see what happens if any thing
paul
Dont flash the lights Pull it all the way back to keep main beam on. After the click the timer starts.
