I Think I Need To Replace The Glow Plugs
Hi Guys,
So, in the absence of health and being able to go out and strip the car down to test the glow plugs, I am fairly confident I need them replacing.
Basically if the temperature is just cold to cool (anything above say 7 degrees) the car starts fine. Anything between about 2 - 3 degrees, the car struggles to start, but if I turn the key over (allowing the glow plugs 3 cycles to warm up) then the car starts with only about a second of struggle, but comes to life.
This morning it was -1, so I cycled the glow plugs 5 times before starting and the car came to life with a real struggle (about 4 seconds of turning over before it came to life).
Now, any day where the car struggles to start, if I get the engine warm (even having it register on the gauge, then the car starts fine with no issues as if it was summer!
Im just second guessing myself as I am pretty sure that's what the issue is, but feeling rough and fed up with not being able to diagnose the car properly I just want the clarification!
Anyone else have any suggestions for which I may have missed, or are you all as confident as I should be that I have the right diagnosis :p
Sounds like a good diagnosis Dr Jeebs! Check the power to them first just to rule out any electrical issues like wiring or relay, if all seems ok then change them.
Not sure I have the health to do that unfortunately lol that's kinda why I'm looking to do the blind job :p
Get the Mrs on it with you supervising :)
I would rather invite the neighbours children to just come prod and poke it until it works again...
Can you put code reader on, would have thought 1.8 would use same sensing as 1.6 and 2.0 which triggers dtcs if 1 or more glow plugs out of spec.
Nothing has come up I don't believe but it's been a while, might run forscan on it later this afternoon
P0380/1/2/3/4 are the glow plug dtcs
Will take a look later and see what if any come out.
At least you got the easiest engine to remove glow plugs to check them, think yourself lucky you aint got a 1.6 tdci where they are at theback and snap off in the head.Lol
