Ford Fiesta 1.4 Tdci Cigarette Lighter Fuse Whereabouts
Hello
Trying to change the fuse as the cigarette lighter isn't working. The manual and Haynes States fuse 22 but looking at the location there is currently nothing in that place so could this info be wrong. The only 20 fuses is down the bottom row position 5 and the bigger fuses at the bottom.
Can anyone help ?
Cheers
Matt
Did you check if the other fuses are the same as what the manual says? When I was putting in a fuse for my dashcam I checked the numbers on the other fuses and all were the same as in the manual. If the others are correct then maybe the fuse was loose and fell out? That's assuming the cig lighter socket worked in the first place.
Thanks Phil. Nothing have fallen out and appears from other posts that the handbook isn't correct to the position and cigarette fuse is actually one of the box ones on the bottom fuse. Just awaiting info.
Did you buy the car 2nd hand? If so maybe the seller gave you the wrong manual, so maybe someone else on here with the same age car can have a look at their manual for you.
