Ford Focus 1.8 Td Di Gear Selection Problem
My car had been Ok for sometime, although this moring after it had been sat cold for a couple of days seemed quite stiff changing gears.
It needed a little more effort to get it into gear (any gear). I managed to get to work ok but after driving a couple of hundred yards and stopping at a junction, 1st gear just didn't seem to do anything, I could pull away ok in second and after another couple of nudges 1st seemed to start again OK,,, but after a few more gear changes and a mile or two later, 1st, 3rd and 5th were non existant, no grinding noises unless I pushed the stick very hard(I got a very low grind) and eventually managed to limp home on just 2nd and 4th gear which were the only gears I could feel the stick slotting into, 3rd and 5th if it tried to engage would either pop right out or just not sem to slot into.
I noticed this thread but it seemed to draw numerous conclusions
http://www.fordownersclub.com/forums/topic/36924-problem-selecting-gear-1999-focus-18-tddi/
Although there seems to be some bite in the clutch it is a little high before it engages, but does engage and has never shown any signs that it could be slipping so I've never worried about it.
Has anyone had the same problem, is it likely the gear box is on the way out or could it simply be the clutch, the fact that ot's all 3 gears on the top row and the bottom including reverse is fine is making me think it's the gearbox.
Looking at it from above the only issue I can see around the gearbox seams to be the gear shift retainer looks split and the spring has also seperated.
DSC 0003
Had a fettle with it this morning.
removed the airbox so I could reach the gear lever better and could manaually shift it into gear.
It would bite when manually put into all forward gears but not when using the gear stick, then i'd get 2nd and 4th and only the others at a push.
Pretty sure it is just the cables so will probably try and get that replaced.
Does anyone know if these have to be like for like or can MK1 Petrol engine cables be used in a MK1 Diesel?
Have you checked your gearbox oil level lack of will cause these symptoms top up until it starts to dribble out of the hole this would be one of my first places of call .
Sounds like a good idea, I'll see if my neighbour has the right socket as I don't have anything that fits the plug.
Opened the fill plug, although it is facing up hill on an extremely slight slope, nothing at all came out.
I might buy a litre and top it up just to see if it makes a difference, if it fixes it then I suspect that the gearbox has a leak as there does look to be some around the seam between the gear box and the engine casing
Topped it up but made no difference, going to try and get a set of cables.
Found a dealer that thinks he can get me a pair tomorrow.
  • 2 months later...
having a similar problem with my focus 1.8 tdci estate, did the cable replacement sort the problem?
Was the cable, once I could get a hand onto the gear box I unclipped the cable and it just flopped about, got the part off ebay for £40. Took about 2 hours to do. Spent probably 90 minutes getting the centre console out and putting it all back together. Fitting the cables themselves wasn't too bad. If your finding some gears engage and some don't then it's probably the same issue. Local dealer quoted me £100 brand new. Wasn't just the cables I got off ebay but the leaver also
Thanks for you quick response, I am finding that 1st 3rd and 5th are a problem to find, almost as if the whole 'H' of the gearbox has moved forward and neutral is where 1, 3 and 5 should be. If I select reverse and pull it into position hard, the 'H' appears to move back into place and all gears are available as normal.
You haven't had the cables off by any chance have you what you describe is like when the linkage has been disturb after a clutch change but on the focus the only thing you could do which could cause a similar problem is to have the cables reversed .
STEADS No I haven't had any work done on it, just started playing up one day, nursed it home in 2nd and 4th and has been like that since.
Can you get a look at the gear selector within the car (gear stick) to see if anything is worn or come adrift there or where the cables are on the box that one of them hasn't popped out of place like you state it started all of a sudden could be that something has worked loose come off if I remember correctly when I did my sons clutch the spring lock on one of the cables came adrift and caused a similar prob re did it and it was ok and still is ..
thanks for the pointers, i will get a look at those areas in the morning and report back my findings
Everything you've desribed is the same as my TDDI.
started playing up one day, the next day 1,3,5 wouldn't enagage and I also nursed it home in 2nd and 4th.
If I remember right I had to take out the air intake filter housing to be able to reach down to the gearbox and unclip the cables to try and work it manually, but beware, when buying replacements, the TDDI and TDCI gearboxes are different and so the cables are a different length... this is comparing my 2003 TDDI to a 2003 TDCI.
For the parts alone I was quoted £100 for a brand new set (Don't know if that included the gear stick), found a second hand parts dealer nearby and he quoted £20 but he only had a set suitable for a TDCI (find a decent second hand parts dealer near you, you will get good free advice and he will know someone who will do it for you too if you don't fancy it yourself).
  • 8 years later...
Ford focus 1.5 ecoboost 182 st-line x 2020 automatic
I Have the same problem BUTautomatic  . The message “gear selected will engage at low speed” appeared on my car’s screen, when I changed D to R and at the same time there was a strong vibration-shock in the car gearbox. I sent the car in a specialised garage since it has a guarantee. Three months later since they checked the car, upgraded it and restarted it, they gave it back to me, ready to use. Unfortunately when I drove it for about 300 kilometres, the problem showed up again. My car delivered to the garage again, they checked it and I was stand by, until the factory gave the order to change the car’s gearbox unit .I have already done 200 kilometres with the new gearbox and now the message showed up again in the transition from D to R. . The message turns off immediately after 2 seconds.This problem appears every time I switch from D to R! After the change gearbox the vibration-shock is a little bit softer. What’s the solution? I have read that other customers have also problems like this.
Hey!
I've got the exact same problem (both the message and car violent shuddering when switching to Reverse) on my Focus ST-Line 2021 Automatic 1.0 125, but no solution so far yet... The only difference is that for me it happens occasionally and I'm unable to identify the pattern.
The problem started about half an year after buying the car. It is still on warranty and I've been to the official Ford repair several times because of that. But every time they say that they are unable to reproduce this behavior and they don't get any transmission/ gear box diagnostics errors. Therefore, they cannot fix the issue.
What have been already tried: transmission and gear box diagnostics; gear box oil check and fill; replacement of a solenoid; TCM reset. Nothing worked.
Have you managed to make any progress on fixing this problem, please?
Thanks!
