Wheel Bearing
Hi all please help. I need to change the wheel bearing on my 2003 transit minibus. It's the front drivers side that I am changing.
I need to find out the torque setting for the middle nut if possible. I know it's a 35 mm but when looking on Google it mentioned 420 nm which I think is a bit excessive to say the least.
Please help if possible
Matt
thats the right torque, you should fit a new nut and washer,
pinch nut up, rotate wheel 5 times, torque 250nm, rotate wheel 5 times, torque 420nm
job done.
That's what I read just seemed way too much.
nope, done hundreds of them ,
Where would I get a torque wrench to cope with that pressure please
you might have to borrow one,expensive to buy one for just 1 job.have you removed bearing yet?
Not as yet, doing everything on Wednesday
good luck.
