Relay's
If a relay is 12volt 30amp does it need 30 amps to work??? Thanks for reply's
No. It means the relay contacts will withstand having 12V @ 30A being run through them.
The coil will take 200~mA at 12V.
Whole idea of a relay is that it doesn't take much current to work the coil but it can then switch much larger amounts through it's contacts.
Thanks for the info
