How Come
Does any body know why you don't get a radio code or or key number with a new Ford? I think I was told you have to use the vin number is this correct,Thanks boys and girls
They have no radio code.
You can swap units from another car and assuming they are not a different configuration, will work no problem.
I believe it was deemed as unnecessary as the radios are far more integrated into the car.
The old ones could be removed in seconds, The new ones would require a near on full dash strip to get to.
I thought they were held in by two screws at the base and then you just unplugged all the cables to remove.
Is it more likely that you can't just plug them into another Ford without going into the set up config
