Program Injectors
I really hope someone can help here, I have just bought a 2003 mondeo tdci 130, it requires the injectors codeing, I bought an F Super with formidable v2.03 and I also bought an ELM327 with Forscan, I have tried to use both and the only thing I have been able to do is code number 1 injector, the codes I put into the other 3 don't seem to save only number 1, even though it says programming successful at the end, it's running really lumpy and I'm hopeing once injectors are coded properly it will be fine, any help or advice would be great on this.
Thank You
Dan.
  • 3 weeks later...
have you read the injectors codes correctly, or got the right code to the right injector?
