Focus Tdci Upgrades
Lambda sensor is connected ?
  • Replies 240
  • Views 27.4k
  • Cheers, It's available from Xado in the UK as Well but considering the strength of the GBP against the Euro at present it's around 7GBP cheaper to purchase from Ireland I also use this stuff in a ta
  • Sucking out via filler cap doesn't remove all of this:
Overfuelling can be caused by a number of reasons - a fault code would help in narrowing down the root cause
It could be lack of air too, or just a lack of air, however as the EGRV is blanked the engine should be receiving circa 20% more clean air, so I suspect a fuelling issue - probably injectors
So this could be dangerous for the engine?
Everything went back on correctly. The same way it came off
It's not doing it any good & excess soot is clogging up the DPF too
DPF has been removed hasn't it?
Sent from my HTC One_M8 using Tapatalk
Yeah it has. Would this be the problem?
Unlikely but could be detrimental to back pressure
Could it one of the rubber pipes connected maybe is split?
It should be fine as the cdpf unlike the dpf with eloys has no way of knowing if the dpf is fitted or not as there are no sensors at all. Could be a number of things but you really do need to get the codes read to help narrow it down.
To reiterate - your black smoke issue is caused by an air / fuel imbalance & you must find the cause to rectify the issue & step 1 is getting a code reader on the system to see if any fault codes are logged, & there should be
A split Intercooler to EGRV tube / pipe is always a likely culprit - inspect it microscopically
Anywhere to get the code read cheaply? Or a cheap device?
E bay sellers sell OBD2 readers for around £15
Does it need sorting sooner than that though?
Mine cost less than a 5er and connects to my phone. Works perfectly
Can you give me a link to one at all?
Don't want the car to be out of action
EBay 181813122322 connects vai Bluetooth to android devices
Is it worth not driving it until I find out the issue?
As you have no idea atm why it's thrown the eml on personally I would wait until you've at least read the codes and seen what's the problem. I'm still leaning towards it not actually being the dpf removal and more likely something damaged or disconnected in the process of removal tbh. Since the cdpf equipped focus can't actually tell if the dpf is faulty or removed then technically it cannot be the actual removal that's the problem. More likely something else with a loose broken connection or a unlucky new problem
OK thanks. I got an idea what it may be does anyone have a ford focus I can compare it to?
Mines the same as yours mate 2009 with the cdpf non eloys type. But I'm in great yarmouth norfolk
OK to private message you some pictures?
Yeah no problem mate
