Ford Focus 2010 1.6 Tdci Immobilser Fault
Hi guys need some help I've got an 2011 tdci 16 focus which I bought accident damaged when the car arrived the ecu was missing so I've since got a second hand ecu clocks transponder and fuse box and the car still won't start not even turn over immobilser light just flashes every thing else works ie rcl etc is ther anything I can do to bypass the immobilser or any advice would be appreciated thanks in advance
Are they all from the same car & did you get the key as part of the set?
Yes mate everything clocks key transponder fusebox etc
I reckon you need the keys to be synced to the system.
You should be able to find a local auto locksmith that can do this for you.
I recommend you ring a few for quotes.
Cheers
