Turbo Changes
Hi all how long should it take a garage to replace a turbo my dealer I brought car from picked it up yesterday at 4 I rang him today and they started working on it This morning I was hoping to have the car back tomorrow or Friday I am now thinking with how long it has taken already it might be next week before I see my car again has anyone had a turbo changed and how long did they keep your car as I am going to get it looked at from a different mechanic when I get it back to see if everything had been done correctly as the dealer hasn't giving me much hope till now
1.6 TDCi? Shouldn't take more than a day, loads of access to the turbo but there are a few 'extras' that need doing (cleaning sump etc). I'd say around 4 hours if they're doing it properly and cleaning out the sump etc.
I had the turbo and timing belt changed and the invoice said 5 hours labour.The car was in the garage 4 days.
That's what I'm thinking cause they took it Tuesday
Yes Tom 1.6 tdci as far as I'm aware just the turbo
It's very possible that they have sent your turbo to be repaired by an outside specialist.
Ask them about the warranty on the new/refurbed turbo as the specialists all state the warranty invalid if other work has not been done on the oil delivery system. They do this because they know the turbo will fail again if it hasn't been done.
here's a link for gap turbos
http://www.gap-turbos.com/fitting/fitting-guide/
You will probably have to haggle with them to do the other work and if they won't, I'd advise you to have it done yourself and keep the proof as it is a known fault on these cars.
You may get somewhere with trading standards if needed as there's plenty evidence on line that replacing just the turbo is not repairing the fault, it's only curing a symptom.
Good luck and let us know how you get on.
If I ever get the car back hate having no car lol
As Colin says, if they don't do the other work the turbo will fail again soon...it's not might, it's will lol. So hopefully they are doing that.
These turbo's fail so often that I'd assume the garage would purchase one and then send yours back for reconditioning, it's not like it's a rare turbo that won't be in stock. It's not only your time it wastes but they don't want your car taking up their ramp for days either.
I also hate being without a car so I know the feeling lol, and I would not be happy if 5 hours labour took 4 days lol, so good luck I guess!
Said yesterday it was getting done the bloke has been very arsey with me wanting to find out about my car not the best customer service I have received but funny enough not the worst but I just want my car back I know the jobs that have got to be done with a new turbo I also know that they don't take 4 days and it's not hard to do 50-60 miles then plug in diagnoics to find out if anything else has to be changed I'm just feed up with how I was treated over the bank holiday weekend and not happy with the assistance I got of them just want to be able to go out not take a bus and train to work
ive known turbos to last less than 300 miles if not cleaned out according to turbo manufacturers/ford instructions
What else can cause limp mode garage phoned and said it not turbo
Many things can tbh, DPF, EGR, etc. The garage should have a fault code reader to determine the problem though!
Found out that they only changed the turbo nothing else not oil oil filter dpf etc nothin was changed
The garage should know after fitting a new turbo,a oil change and filter is paramount.
So what was the problem in the first place and what made them think the turbo was faulty
When not if changing a turbo on a 1.6 the oil feed pipe to the turbo should be thoroughly cleaned or replaced along with the bottom feed bolt, as there is a gauze in the bottom one that tends to block up from carbon, the sump needs to come off and pick up pipe should be changed, then a new filter with flush oil and run for a minimum of 10 minutes, then drain replace with another new filter and correct oil, 4 hours including the test drive, or longer when someone has been at it before and round the bolts and over tightened them for the pick up pipe :censored: , absolutely pointless otherwise
Loss of power checked turbo and there was a lot of play also to boost pipe blow aswell
So they changed the turbo (albeit not properly) and it's still in limp mode?
Have they checked to see if the new turbo is dead from lack of oil where they haven't done the work properly? Assuming it isn't dead yet, next thing I would check is the DPF. I would guess it's blocked and that probably finished off the turbo in the first place. Also check the EGR because that's probably stuck open which caused the DPF to clog... Nothings ever simple with a DV6. :lol:
they have been running diagnostics i did say to them check the dpf and it states on a guild to turbo changes that they need to be changed at the same time but as im not paying for it then they cant just keep changing things in a hope that will sort it i have looked up the garage that they dealer took too and there a mot and service garage which i thought was a bit odd cause they wont have the knowledge to do the work and i cant turn around to them and say you need to take it to a specialist to get it done i now have to wait till next week to find out anything as i have barely got any updates up to now except to say i it was not the turbo
If they have advised you it's the turbo that has failed. Then proceeded to change the Turbo and said fault still exists I am almost certain you are not billable/liable to pay for the work already done as they misdiagnosed the problem..
Hope you get it sorted. Out of interest where abouts do you live? I had my turbo changed on my old zs tdci and the garage certainly didn't do it properly as under 1000 miles later it failed again.
I'm certain they changed all the bolts but when I challenged them regarding how common the problem is and had they flushed oil, replaced feeds and cleaned sump etc they got the hump :')
Basingstoke dealer took it to Thatcham have asked for my money back a few times now and i quote he would not do that he will get the car sorted and pay for it but i had car a day and they have had it nearly a week in my book i have every right to get my money back work or no work cause i have been left without a car and they have been rude to me and kept saying cant issue refund or talk to warranty company when i spoke to them i was told to speak to the dealer etc no one has said yes i can do this and you can have it they took the car because my warranty company said i couldn't claim in the first 30 days which i get 3 months of and the first month i cant claim do seem right
Unfortunately it is legal for them to repair the car rather than let you return it. It's not really fair though. :(
i dont think it is either cause they have no idea on how long it will take
Right got a text they have got a specialist coming tomorrow to see if they can sort it and if not then it's going to a main dealer they still haven't took me up on the forum about changing turbos and I hope that it gets sorted
Hi all a little update I have now got to pay for the turbo myself which was 519 pound for parts and labour which I feel I shouldn't have to do the specialist came out dpf was too high In pressure
