Fusion Durashift How To Bleed Clutch ?
Does any one know best way to bleed clutch on fusion durashift please
as no clutch pedal
As i have just fitted gearbox/clutch actuators after repaired, and now need to bleed system
Thanks for any help
The only way in the Haynes manual that doesn't involve pressing a clutch pedal requires a 'pressure-bleeding kit.'
This is from the clutch section in said manual, which according to the Durashift section is the same as the clutch on a 'normal' manual transmission Fusion but with electrical and electro-hydraulic actuators to enable automatic operation.
Hope that helps in some way!
We have just had our clutch actuator repaired, and my husband tried cleaning and replacing before we sent it off. For bleeding he used a 50ml syringe with a tube attached, and just kept sucking the fluid from the bleed nipple, and topping up the fluid up at the top. I have just read on another thread that someone else did the same, but also squirted fluid in through the nipple also. Our clutch actuator is due back today, and he will fit it over the weekend. I hope it solves the problem, as I love my Fusion
  • 3 years later...
Hi anyone how sent the clutch actuator to be repaired after you do clutch bleeding you need to put the car into diagnostic?
